Drafting at a safe distance can give quite a big benefit because it allows you to go slower. If I go slow (say 60 in a 70) then I can fine people not noticing the speed difference and coming up really fast before a "last minute avoid" lane change. If I put myself behind something obviously big and slow then this doesn't happen.
I also use the "2 second rule" to avoid piling into the back of anything, but also being that little bit further back means you can see "round" the vehicle in front more which means you can see obstacles quite a way ahead.
