Old 01-03-2013, 07:17 PM   #15 (permalink)
94CivicVX
Originally Posted by Rusty94cx View Post
I'm not sure that I will put an 02 on the car I might have a tuned ecu and either a 02 delete or calibrate the ecu to run a less expensive wideband. I have many ideas and options. But as you see a hodgepodge of exhaust will work as to weather or not the 02 will last I don't know. Today the tuner told me to move the 02 way past the cat downstream. As the heat kills them. The are just as accurate farther back if the exhaust is sealed properly???? So all the more ideas now.
You cannot tune the P07 ECU. I wouldn't mess with the O2 sensor location either, I'm sure Honda put it there for a reason.
My shift light started working again on the way to work this morning. Weird.
