Old 01-03-2013, 10:45 PM   #38 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Rusty94cx View Post
How To: Determine your gear ratios. - Honda-Tech
Do it right and good luck replace everything you dOnt want to pull that thing out more than you have to.
Thanks! I was thinking of identifying the ratios this way (method from Old Mech, IIRC): "Test to confirm identification of a CX/VX tranny: get an old clutch and mark it at 12 o' clock before pushing the shift rod into the trans, putting it in 4th gear (0.853). Mark the differential. The final drive is 3.25 and 4th gear is 0.853, so 3.25 * 0.853 = 2.77225. Therefore it should take 2.77225 full revolutions of the clutch to make one full revolution of the differential. It should turn 2.77 times and end up pointing a little after 9'o clock to make one full revolution."
