Old 01-04-2013, 09:45 AM   #10 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
The Inverter series generators from Honda use a DC generator but I am not sure what voltage they output to the inverter.
Your treadmill motor idea sounds good, but I am not sure how you can properly size it. Does input power as a motor = input power as a generator? I really don't know.
You are also going to need to throttle the engine to avoid over charging.
Pick up a copy of "The Zero Carbon Car" from your local library:
Aztext Press - renewable energy books, publications, solar electricity, solar panels, photovoltaic, wind electricity,wind turbines,wind power,micro hydro,hydro power,energy conservation,#0443A2 power,passive solar,inverter,batteries,charge controller
The guy in there made a bio-diesel series-hybrid Miata and managed to do exactly what you are attempting, but I forget how....
