Old 06-14-2008, 10:35 PM   #4 (permalink)
Bror Jace
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
Hmmm ... had a 1995 Civic that had a few issues in its 132,000 miles.
How does it idle? Does it hunt at all? That might be a bubble in the cooling system ... near one of the sensors can produce a hunting idle. Might try bleeding the system down in case it got a bubble in it.
Perhaps it is loaded up with soot? What did the plugs look like? I might run a bottle of Red Line SI-1 through the gas for a quick clean-up. I think it's the best of the pour-in cleaners.
I've seen a leaky head gasket produce a surging idle ... same with a vacuum leak ... which may be the case here. Best way to diagnose this is with a UOA ... used oil analysis. Coolant shows up as potassium and sodium in the oil ... as well as accelerated iron and lead wear.
--- Bror Jace
