I failed to mention, thinking some of you may have noticed, that once the Hydrogen is produce and seperated the remaining Oxygen does not get put into the engine. There is a seperate hose that runs off the unit into a filter and aired out into the atmosphere.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
