Thread: Radiator LED
Old 01-08-2013, 07:18 PM   #8 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Just look at your firewall on the front side. There will be holes for heater hoses, HVAC, speedometer (if digital maybe not), steering column, etc. Most will have some sort of rubber o-ring deal to keep moisture out. Pick one that's easy to get to on either side- likely in the driver's foot well. I'd check out the steering column and pedal box first, since you probably wouldn't have to remove dash parts to pull a wire through.
