I have no cat I am too frugal. my very new looking 02 sensor throws 2 fault codes so. Good luck finding one if I were to do it I would convert it to a dx lx ex si style cat under car cheaper more parts I've seen OE style cats somewhere but they were like 400$ you can pull out the 02 and look you'll see the top of the cat there is no way to clean them. You need an 02 wrench or take off the heat shield the bolts will break and a 7/8 wrench. Use some penetrating oil. A vacuum reading will tell you if the cat is plugged. I think it gradually drops.. Buy two sets of center caps for the wheels I need some also.
