Old 01-10-2013, 11:53 PM   #94 (permalink)
oil pan 4
I did some calculations I should have done a while ago.
Figured out I have been running my lithium batteries at up to 22C rate when cranking the engine. This is not ideal at all.
The super battery I am working on will drop the load on the lithium cells down to a very managable 6C rate. If I expand the super battery (drop in one or 2 additional 4 packs of AMP20 cells I could drop the C rate when cranking the engine to as little as 3 or 4 C.
That means the batteries will last a very, very long time. They should far out last lead acid batteries.
