Old 01-11-2013, 04:13 PM   #5 (permalink)
HydroJim
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I'm thinking that the little extra money to replace the rings now might be worth it in the long run because then you're not paying for the labor for a head rebuild and a bottom end rebuild twice.
The engine should be removed for both rebuilds because an in car rebuild means the block isn't being smoothed down which means your head gasket won't last as long.
You should also look into doing the job yourself. it's very easy on the metros and everyone at the geometroforum.com will help you through the process or even come help you depending where you're located at.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
wmjinman (01-11-2013)
