Thread: new truck
Old 01-15-2013, 06:49 AM   #10 (permalink)
radioranger
radioranger
forgot to mention , had the same setup motor wise in a van, the carb is a two piece design and the big phillips head screws that hold the top to the base come loose pretty easy and it will ping on you , offset screwdriver facing up should snug them up , very common and found others with same problem . on mine I made a block off plate for the egr out of a 1/8 sheet of brass stock helped a bit
