Old 01-18-2013, 11:53 PM   #4 (permalink)
HilseeJ
TBA - '07 Honda Fit
Originally Posted by MTXA View Post
If the jerking is caused by misfire
It was most likely caused by a misfire. That's the code I managed to get it to throw after "letting it out"
flashing MIL after EOC is caused by an ECM conflict of seeing vehicle speed sensor input and no input from the cam sensor or crankshaft sensor.
The crankshaft position sensor has been replaced in the last 3 months. Is there a way to stop this from happening?
When it is jerking, look at the short term fuel trim (stft). A negative number indicates a rich fuel mixture and a positive number in excess of 10 indicates a lean condition.
It is no longer jerking. I have stopped using EOC because I'm too scared to have this happen again
Also, I'm losing power steering for about 3 seconds (I believe it's electric, because in my other cars it was gone completely until the engine was restarted)
