Old 01-21-2013, 11:38 AM   #150 (permalink)
Simtronic
Simtronic
Send a message via MSN to Simtronic
Great idea, very similar to mine, I was going down the simple route of no electronics just a heating thermostat bolted to radiator operating central locking actuator when the temperature exceeds 80 degrees just those two components and a fused supply from ignition on circuit. I guess I should also wire a manual override switch in the unlikely event of the thermostat failing
