Old 01-22-2013, 04:15 PM   #7 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
this thread may also help:
http://ecomodder.com/forum/showthrea...tml#post199155
you need to find the wire from the ECU to the injectors then you can duplicate my switch. check Honda forums for a master wire diagram set (my matrix forums had one for me) and start looking for the wire you need.
try this diagram:
Wiring Diagram
you want to add your relay in line with the yellow/black wire after it combines the injectors but before it merges with anything else.
The Following User Says Thank You to Weather Spotter For This Useful Post:
HilseeJ (01-22-2013)
