Old 01-24-2013, 01:05 AM   #8 (permalink)
oil pan 4
Yes cold air is good, rammed air is better but the air can get too cold.
Depending on the compression ratio of the engine once air starts to get in to the 20'F to 40'F range it can delay injection ignition timing.
IDI diesels tend to run higher compression so the ignition delay effect would be restricted to below freezing.
Oh and if it has an EGR, make sure it doesn't when you are done with it.
