Old 01-24-2013, 07:28 AM   #9 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Yes cold air is good, rammed air is better but the air can get too cold.
Depending on the compression ratio of the engine once air starts to get in to the 20'F to 40'F range it can delay injection ignition timing.
IDI diesels tend to run higher compression so the ignition delay effect would be restricted to below freezing.
Oh and if it has an EGR, make sure it doesn't when you are done with it.
I hear you re "too cold"- I'll certainly try to avoid that, as can quite often be below 0 degrees C here over autumn/winter
compression ration on the AAZ lump is 22.5:1- so should be fairly resilliant!
I'm away to google EGR removal
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
