Originally Posted by mort
By scale do you mean 275 whats?
I understand the 275 as you said it is described as the fuel used per kWh. I also see that the horizontal aspect of the iso lines is rpm. What is the vertical aspect of the iso lines? It can't be torque as it extends above the maximum torque curve on this particular graph although most other graphs always stop at the torque curve.
X and Y of the bold torque curve are clearly labeled but all of the BSFC maps I have seen never label the Y axis of the iso lines. Unless this graph is just an oddball.
