Old 01-24-2013, 02:24 PM   #406 (permalink)
freebeard
As far as vortexes go, my reading is that the square edges is where they are created, so image 3 would be the worst for that.
Mine is that vortexes are caused by a pressure imbalance between the top and sides causing air to move up instead of back, so a square section wouldn't shed vortexes. The middle shape is based on a superellipse—half-way between a circle and a square. I see it as reasonable stand-in for the vehicle actual cross section with some height/width adjustment.
Definately want some answers on the contradictions of top taper, side taper and the 22*rule.
Here's two answers
•Boxfish
•Tromphenwagen
