Old 01-24-2013, 07:05 PM   #154 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by echo-francis View Post
I decide to give you more info about my led conversion
according to my owners manual my 1157 bulb draw 27w each while not flashing..
my rear sidemarkers draw 5w each. my brake/tail draw 21w each while not breaking. my license plate lights draw 5w each.
for a total of 116w not counting the headlights 55w each
my leds lights draw an average of 1w each
for a total of 8w
so my lights power draw got from 226w to 118w
I am contemplating converting my rear tail lights over to LEDs on my 2002 VW jetta TDI. I have (4) 21 watt incandescent bulbs and (1) 5 watt bulb for the running light in each tail light assembly. One of the four 21 watt incandescent bulbs is yellow/orange so I will use a 3 watt yellow/orange LED for that one. All other LEDs on the tail lights are red. For my brake light I will use a 5 watt red led and the others will be 3 watt LEDs. I will be using appropriately rated constant current LED drivers for all bulbs and not the resistor based circuits that are extremely wasteful. My question is that with the LEDs do you all think they will be bright enough?
I don't want dim bulbs-especially the brake lights that's why I'm going for the 5 watt red LEDs on those. I choose a wavelength of Red LED that should be comparable to the red tail light lens/filter so I am hoping that the lower wattage LED with appropriate wavelenghth will be allowed to easily pass through increasing visibility while decreasing electrical consumption at the same time. I will also be fabricating a custom heat pipe based cooler to passively remove heat from the LEDs so I get max light output while retaining bulb longevity.
With the constant current drivers and all LEDs needed it will be about $52.00 and take about a month to come from China. I don't mind putting in the time to put it together electrically and also to create the LED cooler assembly. I am getting darn tired of changing these incandescent bulbs and chasing intermittent connection gremlins on my vehicles external lighting so this should reduce my long term maintenance demands. For reference, do the drop in LED replacement bulbs with low wattage give the same visual effect as the standard incandescent bulbs? Any help would be greatly appreciated!
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
