Old 06-16-2008, 06:17 PM   #15 (permalink)
Volones
Originally Posted by SVOboy View Post
Volones, WD40 isn't a lube! I'm surprised your chain didn't blow up after wd40ing it and not relubing!
It actually does have a small amount of lubricant in the formula, which is why it would last for a couple of months instead of 5-6 months. Also, we're discussing a 7-speed Shimano STX drivetrain, not your fancy racer type 10-speed Dura Ace.
I do agree that is isn't the best choice, but for an old 70's Schwinn frame commuter, it got me from A - B and back reliably.
BTW, did you come out here to road Nats? If so, you're in trouble for not saying anything so I could spectate (although I would have to wear my CU Cycling t-shirt).
Finally, chains -
Shimano chains are supposed to be fine, and I've never had a problem with them as far as strength, but I've heard much better durability with SRAM than any other brand. Plus, the master link is so nice!
Check out...
www.mtbr.com
and
www.roadbikereview.com
for opinions from other cyclists on a variety of products.
*Time period is from 1 January 2006 - 1 March 2007*
