Old 01-31-2013, 06:43 AM   #133 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
The warm air is sucked in before the filter. The map sensor is mounted on the throttle body and the iat is on the intake manifold. The only downside that could come from this mod is if the air gets too warm. I've read around 100 degrees is optimal but if it's higher it might work against you
