Old 06-16-2008, 11:20 PM   #1 (permalink)
88CRX
88CRX - '88 CRX Standard DX
90 day: 32.74 mpg (US)
IS250 - '07 IS250
90 day: 25.79 mpg (US)
RX300 - '00 RX300
90 day: 18.38 mpg (US)
Germans trying to replace Alternator with Thermoelectric Generators or TEGs
The alternator may be a thing of the past:
Here's the link:
Up in Smoke
This is the article:
New technology promising to cut CO2 and save gas
Alternative energy comes from unusual sources -- huge rivers, massive arrays of silicon panels, nuclear reactions, and massive spinning metal blades. But German researchers are getting power from a source that might strike scientists from decades past as particularly peculiar -- they're making power from automobile exhaust gases.
In an era of ultra-expensive fuel and concerns about emissions fueling global warming, the automobile has come under increasing scrutiny with users looking for ways to extend gas mileage and cut emissions. Fraunhofer-Gesellschaft, a leading German research organization, is developing materials and designs for a thermoelectric generator which will help to solve both problems.
In automobiles, two-thirds of the fuel used is emitted as waste heat. In total, 30 percent of the energy is lost in heat from the engine block and a further 30 to 35 percent is lost to exhaust fumes. Many teams of researchers have began to look at how to recapture some of this heat and heat from similar industrial engines and transform it into electricity. Such devices are known as thermoelectric generators or TEGs for short.
The TEG generator takes a temperature gradient, driven by the difference between the waste heat and the ambient temperature and uses that gradient to produce electricity. Greater temperature differences yield great results. The Fraunhofer Institute for Physical Measurement Techniques IPM has a number of thermoelectric materials under development that will harvest this heat in automobiles.
Dr. Harald Böttner, head of the Thermoelectric Systems department states, "The temperatures in the exhaust pipe can reach 700 degrees Celsius or more. The temperature difference between the exhaust pipe and a pipe carrying engine cooling fluid can thus be several hundred degrees Celsius."
The thermoelectric converter the team is developing takes the gradient created by the exhaust gas and uses it to drive charge carriers through a semiconductor. This creates a looped current flow similar to a battery. The technology is relatively straightforward, but the real challenge is finding optimal thermoelectrics with high carrier mobility. The research team is hoping that the device will make the alternator obsolete, providing power to the car's consumer electronics, onboard computers, and charging the battery. Böttner states, "This would make it possible to cut gas consumption by between five and seven percent,"
Researchers point out that with 50 million cars on the road in Germany with an average on-road time of 200 hours a year per car, if only one kilowatt each was produced by the TEGs, this would amount to ten terawatt hours per year.
The researchers are hoping to begin to construct prototypes of their designs very soon.
