Old 06-17-2008, 12:06 AM   #10 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
I pinned the adjusting wedge so it can't over adjust. also have small stainless steel springs holding the front pads off the disc. i check them often and adjust if needed. in addition i drill a small hold in the wear face of the drum to let out dust which can cause drag. but then i try to drive without using brakes. a set of pads usually last me about 90.000 miles.
