Old 02-03-2013, 04:39 PM   #7 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
My grille is fully blocked, except for a small opening under the license plate. You can't see that opening in the photos. The air going into it is moving straight up.
I only saw the temperature rise once. It was a 93 degree day, AC going, and a long upgrade. The rise was only 5 or 7 degrees F, not enough to turn on the engine cooling fan.
The best place for getting air to the radiator is low and center - that's where the highest pressure is found. All vehicles are different, so you will need to find out for yourself what works. The above advice about making sure that all air goes through, not around, the radiator is 100% correct.
