Old 02-03-2013, 09:39 PM   #189 (permalink)
TheSGC
I've had a busy weekend mounting plates and clutch to my Warp 9 and breaking in the brushes.
I also rebuilt my transmission today.
The inside of the transmission looked brand new. I only found two bearings that had issues. The Input Shaft Bearing has excessive grinding noise to it (which is the problem bearing I expected) and the bearing at the other end of that shaft has excessive play and fell right off the shaft. I replaced those two bearings and some oil seals and all I have left to do it seal up the transmission and test the setup on the floor.
I'm watching the weather this week looking for a time where I can drop in this new setup, assuming it all goes good in my test run.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
