Old 02-05-2013, 11:54 AM   #62 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
There is another misconception about gearing that is related to energy. Motorcycle guys often change the final gear ratio by changing sprockets since it so easy and cheap to do. I went 15% longer for better fuel economy. Some guys go shorter for better acceleration and to get what they believe will be closer gear ratios. The interesting thing is that the rpm change between gears stays exactly the same either way. If you run 1st to redline at 10,500 and the rpm drops to 6,600 when you grab 2nd, that difference will remain the same regardless of what changes you make to the final drive. You would have to change the gear sets in the transmission to make the rpm drop to be closer between gears. But why do the gears FEEL closer with a lower final drive and FEEL so far apart with my long gearing when you are getting the same rpm drop as before? Because each shift point is now closer together in Energy with the shorter gearing.
