Old 06-17-2008, 09:38 AM   #19 (permalink)
awillard69
awillard69's Avatar
Dakota - '00 Dakota Club Cab, Sport
90 day: 19.71 mpg (US)
Jeep - '01 Wrangler TJ Sport
90 day: 16.95 mpg (US)
I'm running "arduino" in the arduino-0011 folder. It's basically a shell script:
Code:
#!/bin/sh
CLASSPATH=java/lib/rt.jar:lib:lib/build:lib/pde.jar:lib/core.jar:lib/antlr.jar:lib/oro.jar:lib/registry.jar:lib/mrj.jar:lib/RXTXcomm.jar
export CLASSPATH
# put the directory where this file lives in the front of the path, because
# that directory also contains jikes, which we will need at runtime.
PATH=`pwd`/tools:${PATH}
export PATH
# put the directory with the native RXTX libs in the library path
LD_LIBRARY_PATH=`pwd`/lib:${LD_LIBRARY_PATH}
export LD_LIBRARY_PATH
java processing.app.Base
Nothing special there. I compared it to the Windoz version, and it seems comparable. So, maybe there is a bug in the Linux variant. I'll have to try to find a different machine to use the IDE and see if it actually matters.
