Old 06-17-2008, 10:28 AM   #3 (permalink)
PaleMelanesian
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
The difference in coasting distance is huge. You're absolutely correct about it still consuming fuel. I'd say it depends on your speed. If you're going 55mph or more, coasting at idle isn't much different than with the engine off. If you're going 5mph, you're almost idling at a stop, which gives you zero mpg. As always, "it depends".
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
