Old 02-17-2013, 05:06 PM   #48 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by XYZ View Post
So what happens in the summer when temps are 90+ degrees in the shade, and much higher under the hood?
Or do you just rip all this stuff off and start gluing it back on in the fall?
Not sure how this would play out in summer. My plan was to use riv-nuts for the foam panels so removal would be reasonable.
I definitely think you need a digital engine temp display (ScanGauge has it) if you do any of these mods, also if you have a grill block.
That said, with Eco-driving , the problem isn't usually overheating, the concern becomes keeping the engine up to the desired temperature.
Coast long and prosper.
