Old 02-21-2013, 06:33 PM   #48 (permalink)
niky
Too bad you can't get stratified fuel injection there. But I think the biggest problem with modern diesels is the DPF regeneration schemes which hinder biodiesel use.
Originally Posted by razor02097 View Post
I'm not comparing anything. I made a statement. The article posted is what compared the cruise to the chevette.
You stated:
With all of the new car standards and the EPA sticking their head up the OEM's butt the best they could do is match a 33 year old car's fuel economy...
Which implies no progress was made.
The Cruze Diesel is one-and-a-half size classes larger than the Chevette, much safer and a whole lot faster, yet gets around 25% better economy, with an automatic.
I'd call that progress.
The metric you're using is completely wrong. If you look at the mpg per carrying capacity, the Cruze's advantage isn't a mere 25%...
