Tubless tire repair kit information
Originally Posted by newtonsfirstlaw
...I also forgot to pump up my tires before I went out. The other ones are probably ok, but there is one tire with a screw embedded in it that loses 20 psi in a week, and that certainly affects my gliding.
I assume you have tubeless tires. You can easily fix that with an el-cheapo tire fix kit. I've done it to so many flat tires that I now keep one of those kits in my car.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
