Old 03-08-2013, 08:15 PM   #8 (permalink)
TheSGC
Is there not a switch to disable accelerator pedal regen? That would make for easier coasting.
The sedan I drove had a switch: you could choose between "normal" operation (with regen mainly on the brake pedal), or "1 pedal" biased operation (with variable regen on the "first" half of the accelerator pedal travel, and power on the 2nd half of travel).
I am not sure if there is a switch or not. It might have separate pedal sensors so I'll check it out when the weather is better.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
