Old 06-18-2008, 06:24 PM   #3 (permalink)
AXMonster
British Ecomod Hypermiler
AXMonster's Avatar
Foci - '03 Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
The AXe - SOLD - '97 Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
You'd probably need to adjust the O2 sensor's output so that the ECU thinks its running stoich when its actually running lean.
Here's some interesting info:
http://www.civicvx.com/lean_burn_info.html
There is a circuit that can be utilised to adjust the O2 sensor output, but I can't find the link.
Edit - Found it http://www.alternative-energy-resour...tallation.html
And available from the designer here http://www.eagle-research.com/store/...products_id=16
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
