Old 06-18-2008, 10:48 PM   #1 (permalink)
CorollaMaster
ecoRolla
CorollaMaster's Avatar
Sippin' Subie - '09 Impreza 2.5i Hatchback
90 day: 26.3 mpg (US)
Send a message via AIM to CorollaMaster
2008 Corolla 1st Aero Mods
Nothing overly special here, but after becoming a little more familiar with my Scan Gauge and getting a feel for my driving, I felt like I needed to take it a step further. So here is my first attempt at an Aero mod! Rear wheel skirts! And I have enough coroplast left over that I'm going to try and do the front wheels as well!
Overall I think the whole thing took me about 2 hours to do for the rear skirts.
The Materials:
2 4x4 sheets of blue coroplast
1 3.5x4 sheet of white coroplast
it was 40$ for both (Ripoff!)
2 shelving rack rails
8 screws
Drill
Zip ties
1 Can of Black spray paint
All weather duct tape
TOTAL COST: Around $57
Here's a pic of all the materials I used
Next, I set out to try and figure out how to cut this thing to shape. I wasn't sure at first what to do, so I traced the general figure with a marker onto the white coroplast, and then drew another line about 2 inches beyond that to give me some leeway.
Then I figured it would just cut slits along the top to allow for bending, that way it would fit snug and I wouldn't have to worry about gaps or holes.
Unfortunately, it didn't really fit that well. The edges weren't really that smooth with the surface of the car and it was pushing itself out of the wheel well due to the pressure from the folds. It looked alright, but I wasn't really satisfied with the results, so I decided to try it again with the blue coroplast.
With the blue coroplast, I decided to cut it directly to the shape of the wheel well, but this time with flaps at the bottom and the top.
It fit much more nicely!
After that I spray painted them black. While the paint was drying, I decided to bend the brass shelving rods I had bought from the hardware store ($2.59 a piece for 48 inches) These were used to support the bottom part of the skirt and to keep it away from the wheel while I'm moving. The metal was actually very easy to bend by hand!
Once I had the metal bent, I put screws part way on the metal rod and into the coroplast, then I screwed the rods into the plastic body parts of my Corolla. It wasn't looking too badly now, the only thing really left was to deal with the gaps between the skirt and the body of the car.. nothing a little duct tape can't fix!
And here's the final result!
I don't have any hard results as to improvements in fuel efficiency yet, but I promise I'll post them when I do! I plan on doing a drag coefficient test, much the same as AndrewJ did earlier in Feb with his civic. The drag coefficient stock on the Corolla is .30 which isn't too bad!
I'm hoping to replace the duct tape with something a little more aesthetically pleasing? Any suggestions? Thoughts? There's always room for improvement, especially with this being my first mod! Hopefully many more to come
Thanks for lookin
2008 Corolla S - 11,000miles
Pre-Hypermiling Tank Average ~34mpg
First Hypermiling experiment w/o ScanGuage 43.4mpg
Hypermiling with ScanGuage around 51mpg!
