Old 06-18-2008, 11:18 PM   #340 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by MilesPerTank View Post
Is the software operating under a condition that would need the microsecondspergallon value of one injector to be divided by the number of injectors?
Yes, if there are other injectors squirting fuel then it may just be as simple as that. A larger microseconds per gallon will give you better mpg, a smaller one means it takes less time to squirt out a gallon. So I think your example left like 350 seconds/gallon after deviding by 4. There are still a lot of variables like fuel pressure, but you will be within an order of magnitude. I'd guess 500 seconds a gallon. But remember to get the distance/speed sorted out before adjusting the fuel.
