My VSS gives a signal whenever turning with or without a car hooked to it.
My KEL injector based computer switches to gal per hr if it sees no VSS signal.
Problem is during EOC it turns off because the injection signal is what turns it on and keeps it on. Instead of sensing either signal. ithink, i better double check that.
