Old 06-18-2008, 11:50 PM   #38 (permalink)
blownintegra
Green Machine - '92 Metro XF i
Last 3: 42.66 mpg (US)
Black Ball - '99 Contour SE V6 Auto
Red Baron - '96 Civic HX
you can use nailpolish remover, which is basically watered down acetone. then get "wet or dry" 1500 or 2000 grit, wet sand the covers and work the plastic with the buffer off of the car.
The only problem is that one the uv protection in the plastic goes, the lights will not stay clear long, especially if you live in the deep south.
but they will look nice....
