Old 03-19-2013, 01:53 PM   #10 (permalink)
SCNTN
SCNTN's Avatar
SC1 - '02 Saturn SC1
Team Saturn
90 day: 41.8 mpg (US)
DaGnoma - '02 GMC Sonoma SL
Pickups
90 day: 25.03 mpg (US)
What is your engine and transmission?
Vortec 4.3L v6, NV3500 5-speed, GU4 3.08 rear axle
Originally Posted by justme1969 View Post
That looks really good if you decide to make it permanent then cover with plastic and pressure sensitive tape then begin covering it with impregnated fiberglass cloth. you would have some money tied up in it but it would be longer lived.
That's the plan. Although I think I'm going to go with a few skim-coats of exterior wood glue over nylon tent fabric, then primer and paint.
I still have several areas to finish the detail on, mainly the forward and rear ends of the cap. I have to remove the cap from the truck to work on those areas, and I plan to post some more pics as that work progresses. I have to source a 2x6ft chunk of Lexan to build some windows out of. I may have to make a split-window design, since I haven't been able to find a piece longer than 4ft here locally.
Go Team Saturn!
Coming soon... aero accessories by LowCd!
The Following User Says Thank You to SCNTN For This Useful Post:
aerohead (03-19-2013)
