Old 06-19-2008, 09:06 AM   #6 (permalink)
MechEngVT
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
Originally Posted by blackjackel View Post
well from my study into tires, I've seen that there are different TYPES of tires...
Touring
Highway
Sports
Which would be the most fuel efficient of these? nobody seems to say :/
The Highway tires. It's a marketing description and different models/manufacturers will have different results (YMMV) but generally "highway" tires will tend to have a ribbed tread design with circumferential grooves being more predominant than any axial grooves. This helps them roll in a straight line with much less noise/resistance but hurts cornering ability.
Touring tires would be a good mix as they try to be more of an all-around tire for vehicles that do turn and would probably have better wet traction than a highway tire without a significant increase in rolling resistance.
Sports tires sacrifice everything for traction. They'll be heavier to support high side-loads, softer for better traction all around, and the tread blocks will be shorter to prevent squirm (raise the confidence near the traction limit) but will therefore reduce wet handling and tread life. Probably the highest rolling resistance tires you can find.
