Old 06-19-2008, 07:44 PM   #8 (permalink)
88CRX
88CRX - '88 CRX Standard DX
90 day: 32.74 mpg (US)
IS250 - '07 IS250
90 day: 25.79 mpg (US)
RX300 - '00 RX300
90 day: 18.38 mpg (US)
Originally Posted by apgrok1 View Post
I would say that the zippy noise is the clutch solendoids redirecting the flow back to the clutches. They turn on and off several times a second to get the correct shifting firmness. Auto trans gears are always meshed, there is no sliding past one another. Also, I don't believe that the trans shifts in neutral when coasting. What you are probably noticing is the lock up converter disengaging. I have noticed that if you leave just a tiny bit of foot in the throttle, it will stay engaged.
Your saying the torque converter is still engaged, only the lock is disengaged when in neutral. If so, then i should still feel the car engine brake, or accelerate when i push the gas. It doesn't engine brake or accelerate when in neutral.
