Old 01-01-2008, 11:31 AM   #1 (permalink)
Lazarus
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Direct Injection Ethanol Boosting + Turbocharging
This is over a year old. Has anyone heard if they done anything with it? It's a very interesting idea and straight foward.
The foundation of the approach is the enhanced knock suppression resulting from the separate, direct injection of small amounts of ethanol into the cylinder in addition to the main gasoline fuel charge.
Efforts to improve the efficiency of the conventional spark-ignition (SI) gasoline engine have been stymied by a barrier known as the knock limit. Changes that would have made the engine far more efficient would have caused knock (spontaneous combustion).
The injection of a small amount of ethanol into the hot combustion chamber cools the fuel charge and makes spontaneous combustion much less likely. According to a simulation developed by the MIT group, with ethanol injection the engine won’t knock even when the pressure inside the cylinder is three times higher than that in a conventional SI engine. Engine tests by collaborators at Ford Motor Company produced results consistent with the model’s predictions.
With knock essentially eliminated, the researchers could incorporate into their engine two operating techniques that help make today’s diesel engines so efficient: a high degree of turbocharging and the use of a higher compression ratio.
The result is a gasoline engine with the fuel efficiency of current hybrids or turbodiesels—up to 30% better than a conventional gasoline engine—but at lower cost.
"Judge a person by their questions rather than their answers."
