Old 06-20-2008, 12:14 PM   #4 (permalink)
ttoyoda
ttoyoda's Avatar
When you finally DO turn on that ac clutch it will use electricity.. If you are going to charge the battery at home, and this is just a fail-safe for you then it might be ok.. Although you might get the same effect from switching the alternator off (the rotor field coil, NOT the big output wire)
