As a replacement for duct tape, I would use vinyl. A sign shop should be able to sell you raw Vinyl for relatively cheap ... It will stick to the car, and will not damage the finish over time ....
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
