Originally Posted by cfg83
metromizer -
Welcome to EM! Here's mine (I flip a switch just like you said) :
My Eagle Research EFIE
I don't use it much except for testing. I don't want to make it part of my overall system until I can verify emissions compliance.
CarloSW2
Bingo. Unless you guys are concerned only with your wallet, these lean burn systems aren't good in a holistic sense. (As explained in the post below this one)
Originally Posted by MechEngVT
You also don't want to run lean-burn for too long because you may cause damage to your catalytic converter. The cats require the switching between lean/rich to properly function as both an oxidation and reduction catalyst. The cat needs a lean mixture to oxidize HC and CO, but then needs a rich mixture to reduce NOx. Without running rich, your cat can't reduce NOx so not only do you emit more NOx, but the cat heats up and can become brittle and crumble from only oxidizing HC/CO which produces heat.
