Originally Posted by aktacoma
so i bought an electric fan and it says it can either push or pull and I plan on grill blocking at the same time any advice?
Most of those fans have an aerodynamic shape to the blades. Mount it to maximise the efficiency of the fan blades, which is usually in the direction of pulling the air though the front of the fan (the open side without the frame in the way). The exception would be where clearance issues prevent the preferred installation position.
Follow Frank"s advice as well. Those fans can draw significant amps.
regards
Mech
