Old 05-10-2013, 08:02 AM   #7 (permalink)
Frank Lee
Back in the day I shoehorned a Toyota engine into a Spitfire. Even with relocating the radiator forward there was no room between it and the water pump for a fan, mechanical or electric. I found some random junkyard e-fan (there weren't many to choose from back then!) from a Simca I think, and after some mods to the blade so I could mount it backwards on the motor, I then mounted the fan assembly to the front of the radiator. I just used manual control; off til temp gauge moved, then on. Worked good.
