Old 06-22-2008, 12:35 AM   #7 (permalink)
crexcrex
crex skirts
Originally Posted by SVOboy View Post
Damnit, I wanted to be the first to do CRX skirts with integrated trim!
Don't feel too badly you can always do the front skirts first after all you will be the first in your neighbourhood................
Here is a tip re weight loss,,,,,,,,,, the calipers on the crx is oversized and can be down sized to loose weight,,,,,,,,,,,,,,,,,, i installed the calipers from a 1987 crx along with the rotors and pads reduced the weight by half on each side, the braking is the same.
In my humble opinion keep away from fiberglass as the material is heavy and dirty to work with and in terms of abs or pvc it has less flex and is harder to form..................looking forward to seeing your skirts including the front any eco tips that you may have would be appreciated.
By the way i have pulled the right mirror and will do the same with the left as i have installed a 17 and a quarter inch convex mirror in the car which gives ne full view of the sides...............you can also use the multi pane rear view mirror..................and say goodbye to the side mirrors
