Old 06-22-2008, 02:59 PM   #6 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
Coroplast is made of polyethylene, so you need to use one of the few adhesives that will work with polyethylene, which is a low surface energy material that most glues will only attach weakly too. If you are careful, (since coroplast is hollow) you can also heat weld pieces of it together. McMaster-Carr sells an epoxy adhesive that works with polyethylene.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
theoteacher (09-26-2010)
