Are you using the VX trans? This may not be the issue but I'm just brainstorming a little here... If you aren't using the VX trans then maybe the VSS in your transmission is operating in a different voltage range than in a VX trans and the VX computer sees this as a malfunction. If you are using a VX/CX trans then forget everything you just read here.
