Hello & welcome,
The tape doesn't melt -- the heat goes back, so the tape really doesn't get very hot.
BTW, I've taken the tape up onto the hood off, and replaced it with a foam gasket to seal out the air (so I can open my hood again!). I had called my local Toyota dealer about getting a proper rubber gasket (like the Camry and the Prius have), but they don't sell it as a separate item.
I also got some 1/8" "Plexiglass" to make proper covers for the fog lights -- I'm going to mark the oval onto the tape, and then stick the tape on the Plexiglass, and cut it out so it fits flush. I'll probably use tap to hold it on, but at least I'll be able to use the lights.
